2007 Aura XE rear sway bar
Hello. Does anybody know if you have to drop the gas tank of a 07 Aura XE to replace rear sway bar bushings? Im replacing the links due to noise and was going to go ahead and replace bushings as well. Just wondered how deep I was getting in. Thanks!
very minimal web check seems to indicate you can use a ratcheting box end wrench to get to the one difficult nut/bolt, but if any of the bolts break, you're screwed and have to take the rear end apart to replace.
Search the net---that's the best I can do. We don't have many Aura owners on the site but maybe one will chime in with the details as this appears to be a common problem w Auras. |
I'll need to look into this as well, my daughter's Aura will need those links replaced soon. One suggestion I'd make is to spray the bolts a few times with PB Blaster long before you attempt to break them loose.
