2.4l: Should I be worried about the timing chain guide tensioner?
Old May 26, 2025 | 10:56 PM
ImperialBlueAura's Avatar
Default 2.4l: Should I be worried about the timing chain guide tensioner?
I've read that this is the most common failure point of these engines, though at 195k I've had no issues yet, and it seems to be most commonly seen with the Equinox and Terrain, which use the later LAF variant. Do LE5s have this issue as well?
Old May 27, 2025 | 08:00 AM
DropDead's Avatar
They all have the issue.
Even though they have updated the p/n numerous times, I have still had better luck with the original ones.
I wouldn't worry about it until you have a little rattle on startup.
Keep up with oil changes, 2500-3000miles has done all mine well.
Old May 27, 2025 | 07:29 PM
Thanks for your response! Trying to stay on top of the oil, it's got a slow leak in the valve cover gasket and I was thinking about asking them to check the tensioner and guide while they're in there.
Old May 27, 2025 | 08:08 PM
grcauto8453's Avatar
Worrying will not make it any better and it will not do you any good either. Some last for 250K miles or more.
Drive it worry free until it tells you to worry.
Old May 27, 2025 | 08:30 PM
Well, the fact that it's an interference engine makes me worry, haha. But I suppose it wouldn't just fail without any warning is what you're saying?
Old May 27, 2025 | 08:39 PM
When she starts talking to you then you can start to, I don't think worry is the right word here, be concerned. She'll more than likely warn you.
Old May 28, 2025 | 08:15 PM
DropDead's Avatar
Do the valve cover gasket, and while they have the cover off they can check the chain.
I had one ion fail at 140k. And another was close to 400k.
Yes, it's a known issue. But no need to stress about it.
My first one failed because the top guide bolt backed out, not even a tensioner issue.
If it's not rattling, I wouldn't touch it.
Old May 28, 2025 | 10:34 PM
5char
Old May 30, 2025 | 12:00 AM
DropDead's Avatar
5char
5char
SillySaturnGuy
Dec 7, 2023 07:24 PM
Josh_F
Aug 26, 2017 05:48 AM
danbob5
Feb 12, 2016 01:24 AM
john doe
May 4, 2014 05:12 AM
autiger
Dec 30, 2008 02:39 PM
