09 Aura front speaker problem
Old Jul 31, 2013 | 11:14 AM
mykall's Avatar
Default 09 Aura front speaker problem
Hi I've got an 09 Aura with a strange problem that started about a month ago. I first noticed it using Bluetooth and what happens is the sound goes very thin and you can barely hear what anyone is saying and occasionally it pops back to full sound. I've determined that the front woofers are working intermittently and this seems to be the reason for the thinness. Has anyone had this problem and since my car is only under the power train warranty this would not be covered. My brother had this happen in a VW and it turned out to be the speakers. Thanks for any help.
MB
Old Jul 31, 2013 | 12:48 PM
My wife has an '09 Aura, and she uses her Bluetooth hookup quite a bit, but she has never complained of any problems ... good luck with yours
Old Jul 31, 2013 | 01:02 PM
Check connections at speakers and radio. Unplug-plug back in a few times and see if that does it.
Old Jul 31, 2013 | 06:48 PM
Paul b's Avatar
I have one that will cut out completely when using the Bluetooth I found if I turn the wifi on my phone off it stops doing that
Old Jul 31, 2013 | 08:32 PM
mykall's Avatar
The problem with mine is it does this with stereo too. Music has only the front 2 tweeters and it is both front woofers every time, not just one. I was hoping that someone knows whether or not the crossover is in one of the two speakers or even in the radio itself. The latter is a possibility because this is an OEM unit and designed for one or two platforms. I've owned this vehicle since it was new and before about a month ago this never happened. I'll try turning the Bluetooth off again but if it is related to pairing with the phone I'm wondering why only now?
Old Aug 6, 2013 | 10:34 AM
Brother I have no idea how the radio is set up in the Aura or my ION for that matter. Still I'd do as suggested ...... check and clean all connections first.
Old Mar 15, 2016 | 09:44 AM
a_bartle's Avatar
I replaced the front door speakers in my buddy's Aura. It was pretty simple once I removed the door panels. Made a huge difference!
Mac_55
Oct 15, 2013 02:11 PM
BoboVicus
Saturn Aura
Jan 9, 2013 11:20 AM
shordinges
Jun 15, 2009 02:21 PM
Plasticmobile
Apr 11, 2007 02:04 AM
Forgiven
Audio/Visual Electronics
Feb 1, 2007 02:12 AM
