5th gearl
Old 10-14-2018, 12:05 PM
pokerpete's Avatar
Default 5th gearl
When going into 5th no grinding like gear is gone every other gear is fine anyone got any ideas
Old 10-14-2018, 01:10 PM
Welcome! However we are going to need some more information about your car. There are many Saturn models and they all use different transmissions.
Old 10-14-2018, 01:22 PM
pokerpete's Avatar
Default 5th gear
08 Astra 1.8 live catchiest got it would love to have 5th gear
Old 10-14-2018, 11:32 PM
First you need to remove the shift linkage and make sure the problem is inside the transmission. Fifth gear is under the end cover outside of the main case. You can remove the cover and take a look, it might be as simple as a shift fork needing to be replaced. It also may not have any teeth left and you need a complete rebuild. Sometimes you can just replace 5th gear components with the trans still in the car. There is an exploded view on the internet, just look up a Getrag f17 transmission. It is listed as a Vauxhall/Opel transmission since that is what your car really is.
pokerpete
Saturn Astra
10-15-2018 06:01 PM
mandee_07
08-29-2015 02:16 AM
lukesteeler89
07-22-2013 01:57 PM
Rubehayseed
09-29-2012 02:13 PM
whitewtrkayaker
11-23-2008 06:29 PM
Quick Reply: 5th gearl
