-   Saturn Astra (https://www.saturnforum.com/forum/saturn-astra-32/)
-   -   Misfire (https://www.saturnforum.com/forum/saturn-astra-32/misfire-13631/)
Richie7930 Feb 19, 2025 09:10 PM
Misfire
1.8litre 2009 astra the car runs great when cold started, after driving for about a mile or two it gets a bad misfire sometimes on more than 1 cylinder, after driving for a bit it goes away in the lower rpms and progressively goes away in higher rpms until its just gone and runs amazing after not sure what the issue could be. I just fixed the fuel pump and its getting good pressure
derf Feb 20, 2025 02:52 AM
Codes?
And what are the codes present in each operational mode described?
Why was the fuel pump replaced?
grcauto8453 Feb 20, 2025 03:19 PM
Sounds like it develops a leak with the expanding metal. Intake gasket maybe. Need the codes and be ready to test.
Richie7930 Feb 21, 2025 12:34 PM
it ended up being the ignition coil pack
derf Feb 21, 2025 01:17 PM
How did you diagnose it?
Richie7930 Feb 22, 2025 11:11 AM
i remember that a friends chevy cruze with the 1.8 was having similar issues and it it solved his problem so i took one off a parts car he had to see if it helped and it did
derf Feb 23, 2025 10:26 AM
Works for me
