intake throttle body coolant hose
Hello evereyone ,
I have a Saturn astra 2008 xr with the following problem
I had a leakage from a quick connector,this connector has a hose who will passed by and is connect with the intake throttle body. I understand that this hose is for preventing icing. I love in a country who hasn't winter time, can I jammed the nipple with two component glue or this is not a good idea?
Unless the quick connect part is prohibitively expensive or can't be found in a junkyard/the internet, just replace the connector. I wouldn't think you'd want epoxy in constant contact with high temp coolant.
