aftermarket exhuast
i drive a saturn astra vxr for a daily, i love it, i have the 5 speed and ive fallen in love with it. i want to put an exhaust on it, give it some personality. i dont want something thats as annoying or raspy as a straight pipe but i want it to be pretty loud while still having a good tone. i was looking at my car on the lift the other day and i think im gonna straight pipe it after the cat then put one of those exhaust tip muffler combonations, suggesttions would be appreciated
Blow the baffles out and see what it sounds like. Might not want to add anything. She'll purr loud.
Scorpion and Cobra stainless systems can be imported from the UK (middle silencer to muffler to tips.
However, the US exhaust manifolds with integrated cat can be sourced in the US from several sources. The second cat can be found in Canada |
The ex manifolds have a pre cat, not the only cat, correct?
This is the exhaust manifold with cat
https://www.magnaflow.com/products/5...ytic-converter This is the flex pipe with second cat (I don't know anyone else who sells this. https://mufflerexpress.com/products/...flex-1-8l-obd2 Behind that there is a resonator and then a muffler. The resonator looks like that of the Chevy Cruze z18xer but I'm not sure it is exact fit. FYI - The European Astras have a different emissions scheme. They usually do not have the second cat (and I think the manifold also is different but didn't look). Plus they run a hotter thermostat temp. |
(Post 73389)
Magnaflow makes some high-quality stainless exhaust components for the Astra
1. Exhaust manifold with first cat 51150 (in stock) 2. Front flex pipe with second cat 52475 (available August 2025) ***Magnaflow told me 52475 will be restocked in August 2025. Call them now if you might want one. For rear parts (resonator, back pipe, muffler), I found 2 shops in the UK that make stainless (Cobra and Scorpion). There are cheaper front parts in the US but most are not stainless. https://www.magnaflow.com/products/5...ytic-converter https://www.magnaflow.com/products/5...ytic-converter |
| All times are GMT -5. The time now is 03:04 AM. |
