where are transmission mounts at?
got a 2002 sc2 and lately the 1-2 shift seems different .feels like it might need a trans mount maybe .
where is this mount?the only visable mount i see is on the passenger side up top and that one looks good . use to me a smooth shift from 1 to 2 but now it seems like when it shifts the car kinda "rocks" i wanna say .not sure any other way to describe it . like theres a loose something . just need to know location of any and all mounts so i can check them . thank you |
Swing by your local AutoZone (O'Reileys, Pep Boys, whatever) and pick up the Saturn Repair Manual for your car (it'll cost about $25). There are pictures in there that show the location of the mounts far better than I can describe with words, and besides, if you are planning on working on your car, you'll need it anyway.
i will have my mechanic do it ,but if i know ahead of time what it needs i can pick it up and he just charges me labor then .
Do you know what a bad mount looks like on the top of the passenger side?
yep pretty sure i do ,but i will give it richpin`s pen test today and verify .
this rocking motion feels like a trans mount to me .car gets inspected this month so i`d like to know whats what before sending it in . f it wasnt so darn cold n windy here i`d tear into it and see but my only recourse is working outdoors and its way to cold . |
Have someone run the car from drive to reverse and see how it reacts after you see if a pencil fits between the metal strap and rubber. Rubber cracked and rotten. Talking about the TOP mount.
checked the top mount and although it looks good and not cracked or rotted a pen slid right in between the rubber and top of the mount .i know where all the mounts are now also .i still believe the trans mount needs replacing too .hard to see it fully without removing tire and splash shield .
car has 97,000 on it now engine bay is clean . |
Pens come in all shapes and sizes......thats why a standard #2 pencil is the best test. If the #2 pencil fits snug your good. Fits sloppy, very sloppy, real sloppy well then you have something going on that you want to repair.
the pen used had more width than a #2 pencil and it slid right in .
Originally Posted by john doe
(Post 34438)
| All times are GMT -5. The time now is 09:36 AM. |
