Using Storm TB coolant ports
Old Mar 27, 2016 | 06:12 AM
Felixthekat's Avatar
Default Using Storm TB coolant ports
I have read in several places that the coolant ports on a Geo Storm throttle body are useless. I picked TB from a JY, cut out the butterfly plate shaft, ported it, made a butterfly plate by hand, welded the shaft back together and then drilled out the coolant lines. I then drilled at an angle into the TB behind the butterfly plate to match the setup on the SC1 TB. I installed vacuum line elbow connectors into the coolant line cavities and ran vacuum line from the elbows into the TB. I then cut the lines flush inside the the TB and connected the 2 vacuum lines the same way they were on the SC1 TB. Works like a charm.
Attached Thumbnails Using Storm TB coolant ports-picture1.png   Using Storm TB coolant ports-picture2.png   Using Storm TB coolant ports-picture3.png   Using Storm TB coolant ports-picture4.png
Nov 5, 2012 09:00 PM
dijon270
Jul 8, 2012 11:44 PM
BamaSl2
Audio/Visual Electronics
Jan 21, 2010 09:36 PM
saturndriver
Jul 16, 2009 08:54 AM
Bman98SL2
Nov 9, 2005 01:40 AM
