Sunroof leak
Old Mar 31, 2007 | 01:03 PM
hartman's Avatar
My sunroof leaks and i know that there are 4 drains on it and they are clogged ow do i get to them and how do i clean them.
Old Apr 1, 2007 | 01:09 AM
Search function on forum works well if you search in the message body
Old Apr 3, 2007 | 01:19 AM
Low Saturn's Avatar
Old Aug 2, 2007 | 07:44 PM
jwlane's Avatar
You may have already fixed your leak. Here's a link where you can buy the seal for $45.75. http://www.sunroofdoctor.com/
Old Sep 11, 2008 | 01:26 AM
jehamlin's Avatar
Take the headliner out to axcess the tubes.
Old Dec 3, 2008 | 01:43 PM
ASKBCG's Avatar
Hey guys, I found this posting by searching the site, Might as well continue an old one that start a new one, Anyway. I''ve got am ''02 SL1, and water is leaking into my car, clearly from the sunroof. Just trying to see what is going on, as I do not have much experience with sunroofs. I see that there are drain tubes, Do I have to remove the headliner to clean them? Do they really need to be replaced if they can be cleared out? Is it ok that the sunroof leaks and I rely on the drains. Or are the drains a backup increase the seal leaks?
Just looking for information and advice, anything would be appreciated!
MJW
Old Dec 4, 2008 | 09:04 AM
Low Saturn's Avatar
Just clear out the drains. If you have access to a compressor, just open the sunroof and bolw the debris out of the tubes.
If there is excess water coming in around the glass seal, then it should be replaced.
Old Dec 6, 2008 | 09:02 AM
ASKBCG's Avatar
Ok guys,
So I tested stuff out today, poored water in, and it took a long time for water to start dripping out. then after a few minutes of testing, it began dripping inside the car. Leads me to believe that the tubes have somehow come unattached. So i guess I have to remove the headliner, and just wondering what is entailed in that, it seems like a large job, and i''m not sure of where to start, couldn''t find anything on the subject in my Haynes manual.
Old Dec 6, 2008 | 10:15 AM
Low Saturn's Avatar
Sounds like the tubes are clogged, backing up and spilling over into the interior.
Start by removing the "A" pillar, "B" pillar and "C" pillar trim. Then the grab handles, sunvisors and dome lamp. Recline the seats all the way and remove the headliner from the car.
Old Dec 24, 2008 | 03:20 PM
Addsk8er15's Avatar
i pulled the tubs all the way out and cleaned them and just fed them back thro.. simple
RedSL2
Aug 30, 2009 08:35 PM
2001s4ny
Jan 18, 2007 04:08 AM
fuego
Jun 12, 2006 01:12 AM
TiaAna8
May 1, 2006 11:51 AM
mjdjlh2000
Jun 23, 2005 05:42 PM
