-   -   sc2 fog light on sc1? (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/sc2-fog-light-sc1-3097/)
a-NiC Mar 23, 2009 02:09 PM
i'm wondering how easily sc2 fog lights can be installed on an sc1. i drive a '01 and the cut of the front bumper is virtually identical as an sc2, so my question is simply would the fog lights fit properly into my car? and what parts/wiring would be necessary? i've only found one set on ebay recently though, where else could i look online? thanks guys.
RjION Mar 23, 2009 08:54 PM
All the parts and wiring would be necessary as the SC1 has none of the items you need. I'd locate a set of lamps with brackets and hard wire them to come on with they key or via a switch that you'll have to install.
a-NiC Apr 6, 2009 02:18 PM
thanks for your response. but in other words your saying its not a real simple job? could it be tied into the wiring of your headlights?
RjION Apr 6, 2009 04:29 PM
Not hard at all, and yes you can tie them into your headlamps if you know what your doing. I'd not tie them into my headlamps in fear of over loading that circuit.
