Just joined the forum.. Hi all :).. and bought me a SC1 for gas saving.. I lowered the front last night.. but the back is still left. Here the questions. How in the heck do I get the back shock out and stuff its like stuffed into the wheel well hardcore. Anyone do a write up on it? thanks everyone |
The rear strut is removed similar to the front strut.
- Remove the carpet on the rear shelf inside the car. - Lift and support the rear of the car - Remove rear tires - Disconnect ABS electrical connector (if equipped) - Remove the two knuckle to strut bolts - Remove the three upper strut to frame bolts - Remove the strut from the car -Remove upper strut bushing -Remove spring Install in reverse order. Extremely simple. I can swap out the springs on a S-Series Saturn in under 45 minutes.Edited by: Low Saturn |
| All times are GMT -5. The time now is 05:24 AM. |
