| carterseth32 |
Sep 27, 2009 09:28 PM |
One reason Saturn is able to use plastic body panels is because of its space age steel frame. ( At least that was the case back in the day. ) That allowed saturn to use the exact same stucture on all the "S" cars because the body panels did not have to carry any weight from the structure allowing Saturn to use differing body panels. So the answer to your question is no! You must find another SC1 or SC2 fender to replace The one on your car.
I would suggest either find a different color fender and have a body shop paint it to match your car. Should not cost to much as long as your paint is not to faded or just buy a new one and do the same. I am willing to bet it will cost you less then $300 either way you go.
