i have a 2000 saturn sc2, its an automatic and when in nutral or park it will only let you rev to about 4000 RPM''s is there a simple way to remove this featur?
Thanx |
No. Rev limiter By design. When signal from vehicle speed sensor {VSS} indicates 0 mph and/or there is no VSS signal at all sensed by the PCM.
Any particular reason you feel the need to approach redline while not moving?Edited by: derf |
Computer controlled, and no good reason to remove it.
| All times are GMT -5. The time now is 08:30 AM. |
