-   -   rear disc (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/rear-disc-948/)
rileyescobar Apr 4, 2007 12:19 AM
is there any way to convert a 2000 sc to rear discs,besides buying a $750 kit?
derf Apr 4, 2007 12:53 AM
Why bother (?)
I do believe the braking power distribution in these cars is 80/20 ish....My rear brakes (disc) lasted to about 150k on both my SC2's (95 and 97)
I suppose you could transfer an assembly from a used older donor vehicle, but that's an "at your own (potential) peril" project....especially if you have ABS......
rileyescobar Apr 4, 2007 04:42 AM
i've done several other rear disc conversions(86 crx,91 escort..and a few others) so the peril is not so great as it seems,i just need to know what "donor" vehicle i need
Edited by: rileyescobar
derf Apr 4, 2007 11:21 PM
You are a better brake man than I...
Don't know the answer-- you could check with dealer (parts dept) to see which rear ends are interchangeable....
sorry I cannot help you more....
Ducky? Ott? Sw2cam?
Any ideas?
Derf
Low Saturn Apr 7, 2007 04:47 AM
All you need is the calipers (1991-1998), caliper mounting brackets (1991-1998), new rotors, pads and you'll need e-brake cables. In your situation, you'll need e-brake cables from a 97-98 coupe or 1996-1998 sedan/wagon with rear disc. All parts can be found at your local junkyard pretty cheap. Shouldnt be more than $100. I can usually get everything for around $40 locally. And always use new rotors and pads.
Rear crossmembers are interchangable throughout all the S-Series years. DOHC's have a sway bar, SOHC's dont.
derf Apr 8, 2007 10:56 AM
Thanks Low Saturn,
Sorry for the inadvertent "dis".
S3aturnR Apr 9, 2007 03:32 AM
listen to low saturn.
but, if you're doing this and you're not using your car in a manner in which you'll be swapping brake pads/rotors once a year, you'll be wasting your money. it won't stop you any faster. it will simply make it easier to work on when you're changing them...
s3aturnr
Low Saturn Apr 9, 2007 12:11 PM
s3aturnr
Thats why I do it. Plus they look nice behind aftermarket wheels.
S3aturnR Apr 9, 2007 05:07 PM
those are, in my opinion, the only 2 acceptable reasons for this swap...[img]smileys/smiley16.gif[/img]
s3aturnr
GarrenNatas Apr 9, 2007 05:56 PM
Ease of work and esthetics... Works for me... lol
