I have a 2001 sc2 . My problem started a couple months ago, the drivers side window would go down but not go back up. Eventually it would go up. But this last time it just stayed down. When I push the switch I could here the window motor click quietly. I have cleaned the switch but that didn't help. I have had the front and back door panels off on one inside there's metal blocking the motor and on the other the window is blocking it. Am I missing something or is there a way to get the window up manually? I would like to try to fix this myself but I'm out of ideas.Edited by: sw2cam |
Remove the outter panel and replace the regulator. Instructions are in the tech section on my website.
Different Racing While someone is pushing the up button, use the palms of your hands and push up the glass.Edited by: Low Saturn |
I figured it out but I'll post how I did it. I just unscrewed the motor housing (4 torx head screws) and the window gear disengaged so you could move the window.
