i have a 1998 saturn sc2 that wont start& nbsp; i turn the key and nothing. i can hear the fuel pump clicks on.i''ve tryed 3 new starters, new batter,cheacked all fuses.i''vetryed tripping the starter and still wont start.if i pop the cluch it will start, but that might bring about someother problems..also the dashlight quit working when i changed out cd players. any answers would be great.thank you |
Did you check if the purple wire on the started gets power when you turn the key?
how would i check the purple with out a voltige tester? and right be for this all happendthe dash lights went out and now my fact kieless dont work eather, ive read every thing inthis forum has no one found y our cars do this??? |
ive read every thing in this forum has no one found y our cars do this???
yes |
mike heres another one under your belt. but i went for the cheapest way out i put in a push butten start now if i can figger out how to get my dash lights worken again thank you!! |
check the clutch switch on floor i had the same problem.
Hmmmm ... looking back over the various comments, I''m wondering if there was either an improper hookup or a loose hookup performed when the CD player was changed out. Comments suggest at least part of the problems could stem from there ...
| All times are GMT -5. The time now is 05:07 AM. |
