-   -   Need to recharge AC, not sure if it's ever been changed (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/need-recharge-ac-not-sure-if-its-ever-been-changed-12136/)
tap4154 Aug 20, 2020 03:08 PM
My 1994 SC2 AC blows cool air, but not cold. AC clutch is working, just seems like it's low on refrigerant. Problem is, I don't know if it's ever been serviced. I suspect not, and if this has R12 I guess I cant mix in R134? Or was R134 in the 1994 Saturns? The manual just says check with the dealer.
Ah, this chart says they switched to R134a in 1994, so I guess I could recharge it. Can anyone confirm?
Thanks, and hi again (was here months ago) ;)https://cimg0.ibsrv.net/gimg/www.sat...c9279de138.png
tap4154 Aug 20, 2020 06:43 PM
Got it solved. Found a sticker under the hood that says it's R-134A. Picked up a can of A/C Pro and charged it up, and it's blowing cold now. That was easy! Actually when I hooked it up it showed just in the green zone around 28 psi, but I filled it until it got to about 42 psi and was blowing cold (50 psi is max in the green zone). Took about the entire can, and supposedly the A/C Pro helps stop leaks. We'll see...
https://cimg1.ibsrv.net/gimg/www.sat...281188718f.jpg
https://cimg3.ibsrv.net/gimg/www.sat...53b8a22e8d.jpg
derf Aug 20, 2020 06:45 PM
Look under the hood. On the main front crossmember is a sticker with all kinds of cool information which includes refrigerant type and total capacity. of system
tap4154 Aug 20, 2020 07:39 PM
Thanks Derf, we posted at about the same time. I did find that sticker, and thanks for the reply and I hope things are going well with you and everyone here.
