-   -   my car will not start (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/my-car-will-not-start-312/)
greggquintos Feb 7, 2006 01:44 AM
i need help..
my car will not start. there's no fuel, i think, going to my engine. i changed the fuel pump, fuel filter, fuel injectors, i cleaned the throttle body and still it won't work. i put starter fluid and it started for about 5 seconds. WHAT's WRONG WITH MY CAR?
ottjoe88 Feb 7, 2006 04:41 PM
check the fuses
greggquintos Feb 7, 2006 09:39 PM
fuses are okay
ottjoe88 Feb 8, 2006 02:54 PM
what year? check the grond wires. I had the same problem one time and i took the wiring harness that goes to the fuel pump out of a 1995 saturn and found that they added a ground i hooked up the ground and the car started right up
ottjoe88 Feb 8, 2006 02:56 PM
so get the wiring harness out of a 1995-1999 saturn and hook it up
greggquintos Feb 8, 2006 11:12 PM
its a 1997 sc1....i checked all the grounds... i did that first because i made a mistake taking it off the first time this happened...
ottjoe88 Feb 9, 2006 04:49 PM
you checked the one in the trunk? if so then check the relays
