-   -   Ignition Cylinder Lock?? (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/ignitin-cylinder-lock-2815/)
richie6 Jan 13, 2009 10:14 AM
Has anyone ever replaced their ignition? Key is stuck and can''t remove it....
Low Saturn Jan 13, 2009 02:04 PM
Yes I have. Usually theres difficulty with the ignition cylinder before the key actually gets stuck. You''ll have to remove the shroud and if you''re luck, when you press the little button to remove the cylinder, it''ll slide out. If not break out the drill/grinder and have at it.
richie6 Jan 13, 2009 02:15 PM
What type of button do you hit...
