Glad to be here!
Old Aug 27, 2024 | 02:46 PM
Don Jr's Avatar
Default Glad to be here!
Hello everyone glad to have flund this group I’m am driving a 2002 sc2 Saturn manuel and I currently have a broken shifter on it and don’t know where to start or how to diagnose
Old Aug 27, 2024 | 05:09 PM
grcauto8453's Avatar
Welcome.
Old Aug 27, 2024 | 06:31 PM
PlanetSix's Avatar
Hi. If, by "broken shifter", you mean the shift **** just flops around loose while the transmission remains stuck in one particular gear, I'll bet your shifter bushing has broken. It seems to be a common enough problem on Saturns that there's a guy on Ebay, whose handle I forget, selling bushings just for this reason that are tougher than the original ones. There are metal ones and plastic ones. I went with the plastic one when I had to replace mine.
It's a fairly simple and easy do it yourself fix, you only need to remove the part of the console that sits between the seats (and covers the parking brake and the gearshift) to get to it.
Old Aug 27, 2024 | 11:45 PM
It's called a shifter cable bushing
His eBay is Saturnbushingman
I put two of the stainless steel replacements in about 15 years ago. No problems whatsoever.
You will have problems if you do not get the stainless steel sleeve made it with the bottom of the shifter quickly enough once you mix the JB weld. If this happens, the bond will last about 2 weeks, then fall off. User error, not product issue. Work faster. Ask me how I know. Dremel out the failed stuff before you try again. Don't take any of the stainless with it or it will be the wrong diameter internally
Old Jan 14, 2025 | 11:36 PM
andreaschen's Avatar
Hi also new to here. I just ordered saturnbushingman on eBay but no shipping after several days. Is his business still active? Can someone call him?
Old Jan 15, 2025 | 07:18 AM
Just just contacted him through eBay on your behalf
Old Jan 15, 2025 | 08:48 PM
No reply
Old Jan 16, 2025 | 05:08 AM
I didn't give him your info, silly. I gave him mine.
Old Feb 15, 2025 | 09:33 PM
Hi just to update: saturnbushingman shipped my order after about a week so totally fine. Stuck with eBay international for about a month (not SBM's fault) and today it's installed. Super easy and perfect fix.
Hornet
Jun 11, 2011 08:54 AM
dealrocker
Jun 9, 2009 07:30 PM
Larissa72
Dec 31, 2007 09:27 AM
redcannon
Jun 10, 2007 04:11 PM
boogawooga
Mar 15, 2006 12:10 PM
