Missing cylinder
Old 02-13-2007, 05:51 PM
Briad's Avatar
Well I have had this 95 SC2 from the dealer, I have 235000 miles on it and just recently I have had to start replacing things. I have started to get a periodic miss. I’ll be driving along and one of the cylinders will drop out if I stop at a light or stop sign the car will stall and the only way I can restart it is to push the gas petal to the floor and it sometimes restart. When it does the cylinder is still out but it comes back. And I am going through fuel like mad. The computer fault codes do not indicate any problem. I have replaced the Coils, the Injectors, the spark plugs, and wires, nothing has changed this. Anyone have any ideas??
Old 02-13-2007, 06:45 PM
S-Turn's Avatar
Any wierd smoke coming out the tailpipe? Does it burn through a lot of oil or coolant? Or what if there's problems with the valves seatingfor that cylinder?
Old 02-13-2007, 06:48 PM
Briad's Avatar
I had a problem wiht the heads but had then Shaved. the compression is About 200 psi in all cylinders. burn about a quart of oil after about 2000 miles, after an oil change
Old 02-13-2007, 07:25 PM
Sounds like classic EGR issue with these cars.
It may feel like a misfire, but it is more likely that the EGR is sticking open when it should be closing (during deceleration) -- the EGR gets gunked up on these cars do to the massive oil burning....
Remove and clean/replace EGR valve. Also check EGR solenoid (though if you're not getting an EGR code or a quad driver output code the solenoid is probably OK)
Also -- if you've never replaced the original engine coolant temp sensor (ECTS), it most certainly has failed (poor design) and is causing car to run absurdly rich-
Replace with brass-tipped sensor and OEM replacement connector -- connector is crucial to proper signal transfer to PCM (see other ECTS posts on this site).
Keep us posted
Derf
Old 02-14-2007, 11:21 AM
Briad's Avatar
The egr valve helped and I cleaned all the contact points for the coils, it is running allot better but still stalls at lights. Last night I replaced the EGR valve the O2 sensor, and today I will replace the coolant temp sensor. I hope that is the last part that I need. I think that I am still using gas but I want to drive it more to be sure. Any one know how long it takes the computer to reset after replacing all this stuff
Old 02-20-2007, 12:53 PM
Briad's Avatar
I finally replaced the engine coolant temp sensor. It runs like it did when it was new... I can't believe that a $12 part was the problem that made it run that bad. After replacing about $350 worth of parts.
Thank you for all of your help.
Old 02-20-2007, 03:08 PM
S-Turn's Avatar
ya gotta love happy endings[img]smileys/smiley1.gif[/img]
teamsaturn125
08-25-2008 08:07 PM
BRG'sFSTSL1
05-19-2008 06:55 PM
lomfs24
06-01-2007 11:38 PM
chamberland_666
04-01-2007 05:05 PM
tiny747
10-29-2006 06:52 PM
Quick Reply: Missing cylinder
