Dome Light Problem
Old 01-05-2007, 11:35 PM
gadawgfan's Avatar
I have a 99 SC2 with the third door on drivers side. The dome light stopped working when the drivers door is opened. Problem is, I cannot find the switch that activates the dome light. Some people say the light works off the door latch, but I can't find how. The passenger door has the normal jamb switch on the "B" pillar.
If anyone has any advice, I would certainly appreciate it.
Old 02-23-2007, 07:46 PM
rickatom's Avatar
try squirting some WD 40 around the latch area in the door. Sometimes the micro switch gets dirty and hangs.
Old 02-25-2007, 10:31 PM
gadawgfan's Avatar
Thanks for your recommendation!! I finally found the problem to be a bad ground----fixed that, and it works fine now.
whitelee28
12-30-2010 08:04 AM
Tobykanobe
08-11-2009 11:17 PM
canarycary
01-12-2009 05:28 PM
bjw109
03-03-2008 06:49 PM
jimmyg
10-02-2007 09:28 PM
Quick Reply: Dome Light Problem
