dies in gear and codes sc1
ok, I have a 93 sc1 twin cam Automatic and it has issues. when I start it it revs up to 2500 rpm for a few seconds and then comes down to normal and kind of stumbles around a little then when I put it in D or R it dies. i can repeat cycle all day. I had someone scan it with snap on scanner and it displayed these codes not sure if related
53 info flag-esc exceeded max value 83 info flag-esc low coolant level but coolant not low. any help appreciated thanks in advance |
53 says the EGR valve is not operating properly. Need to pull it, clean it, clean the ports going to it and reinstall.
83 is the coolant catch tank. The sensor is stuck. Needs to be cleaned and flushed |
cool thanks
| All times are GMT -5. The time now is 03:40 AM. |
