CD Player Shroud Connectors
Hey all, I've been searching for solutions to this problem for quite some time now, and have gotten nowhere. I am wondering if anybody knows where I can buy replacement pin connectors for my center console - these are the pins that you need to push a screwdriver into in order to take off. I broke both of mine when I replaced the stock radio in my 1998 Saturn SC2.
Thanks! |
May just have to go to the junk yard cut off the connector leaving enough wire to splice in the two you need to replace..
1 Attachment(s)
Thanks for the reply.
I figured I would probably end up having to do that. The plastic pin connectors aren't any part of the wiring; they are what holds on part of the center console. Here is a picture I found that looks exactly like my car's stereo. The pin is the small circle on the side of the stereo. It holds on the "plastic covering", if you will, of the cd player. I've attached an image pointing at it, if my description is too vague. Edit: I would take a picture of the pin itself, but I broke both of them when I took out my stock radio >.< http://laruetx.com/autos/Saturn/LaRu...t-d-stereo.jpg |
Oh you need the fasteners that hold the trim on
Those can be had from the dealer ................... easy. |
Thanks a lot. I didn't really know what the thing was called. Time to go to my local Saturn dealer.
gm dealer that is
| All times are GMT -5. The time now is 05:22 AM. |
