blower/heater air volume
seems like these cars done have alot of air volume .even on recirculate it feels like there should be more .
the blower sounds like its moving alot of air but its not blasting out the vents or anything . this the norm? |
I guess that quantity is in the opinion of the operator. The vents were originally designed to move the maximum amount of air possible, without creating hot/cold spots inside the car (read -> it don't blow directly on you). Of course, I'm ignoring the defroster vent in this comment
Pull out the vents, using a flashlight look to see if you have any blockage.
have this car 2 years and it just never seemed like the output matched what i was hearing from the blower motor .
i will shine a light in there tomorrow . |
I had one that the foam came loose and blocked the air. What the hell the foam was for I don't know.
Originally Posted by sw2cam
(Post 35515)
Originally Posted by tymr287
(Post 35551)
What about your evaporator core? Was wondering if its dirty due to a build up of dirt & moisture, it could start to clog up, & start limiting the amount of airflow out the vents. Could use a good cleaning.
Pull the blower motor and with the same flashlight see what you can see.
Possibly a problem that the blend door is not working properly??
nah the blend door switches from heat to cold .maybe theres no issue at all?this is my first saturn and it just seems like the blower is blowing more than what feels like coming out the vents .cold air blows harder then heat does .if that makes any sense?
| All times are GMT -5. The time now is 07:46 AM. |
