JMuse84 |
09-13-2009 11:58 PM |
There is a few ways to do it. but you cant just throw a turbo on a car and throw injectors at it and expect it to give you the fuel you need. You can run MS2 which can be very invasive. You can also get a Rising Rate FMU which cost as much as MS if you get a good one. Or run Auxiliary Injector System which is kinda a crude way to do it. [B]Go get you a Vortec FMU ( 10:1 ratio works good on mine), a decent Fuel Pressure Regulator, a 1-3 BAR MAP Sensor, Walbro 255LPH Pump or equivalent, Set of RC Injectors (500CC or depending on your app.), Take your car to have it tuned ( or send your ecu in with all your specs boost pressures ect). If you half ass it, you will be doing it again. With much more costly consequences.
