'99 SC1 Headlight Malfunction.
Hey again,
So my passenger side low beam quit working, bulb is good, fuse is good. Here's the kicker, when i pull the drivers side fuse out and leave the passenger in they both come on. Drivers first, then passenger. And they are very dim. I'm stumped, any ideas? |
Are the high beams ok? If they are, that would eliminate a bad ground. Has the car ever been in a front end collision?
Sounds to me like your Daytime Running Lights relay (DRL) has gone bad on you. Not sure what a replacement relay costs, but it shouldn't be too much
DRL's and high beams both work(same bulb) The bumper does have a bit of damage, but i bought it like that. I played around with a test light this evening and even with the fuse pulled there was power to the light but no ground.
