97' SC2 Cooling fan not kicking on
Old Mar 24, 2011 | 10:08 PM
pinky2252s's Avatar
Default 97' SC2 Cooling fan not kicking on
So far ive only replaced the thermostat (which was stuck open). The cooling fan comes on when i turn he AC on. But if i dont have the AC on, the fan wont come on and the coolant will get so hot it starts to boil.
What else can i replace, or check?
Old Mar 25, 2011 | 07:20 AM
Replace the engine coolant temperature sensor (ECTS). It sends the signal to the computer to turn on the cooling fan. Good idea to replace the connector for the sensor at the same time (they go bad over time from the heat). Total parts cost will be around $40USD. Sensor is located on the driver's side of the engine, below the thermostat housing (gooseneck). Use Teflon tape on the threads of the new sensor, and make sure it is an OEM-type with a metal (brass) tip. There are some "cheapies" out there with a resin-tip, but they don't last ...
woodsheder
Jun 12, 2012 10:33 PM
Scootertrash
Apr 30, 2010 10:09 AM
jcm22
Jul 9, 2007 11:26 AM
mfunk49
Jan 27, 2007 10:13 AM
one day
Jan 20, 2006 02:58 AM
