Hello, I have a 97 SC1 that the fuel pump will not run on. The fuse is good, and there is power to one contact of the fuel pump relay. Does anyone have a good wiring schematic of the fuel pump circuit or maybe has had trouble before that was an easy fix? I have replaced the relay and that did not correct the problem. [img]smileys/smiley6.gif[/img]The Haynes Manual I have is no good. Thanks, Doug |
I sent you an e-mail as I was unable to upload the diagram here.
I had mine replaced for free via a factory service bulletin about 7 years ago.
Kerry |
all 1997 saturn had fuel pump problems, i would bet that more than likely the pump died
Chris |
| All times are GMT -5. The time now is 08:35 AM. |
