I have a 1993 saturn SC2, twim cammer, auto tranny, full tank of gas. It has a problem, it cranks and cranks but won't fire.My snap-on scanner is not picking up any codes. does anyone have a solution
1) Have you replaced the ECTS (engine coolant temp sensor)?
If the original is in there, replace with brass tipped design and replace connector as well. This is a must irrespective of your current issue (though it may be related) 2) Have you checked for fuel and spark (the basics)? Could be Crank position sensor (CPS) See the following: https://www.saturnforum.com/forum_po...=1507&PN=1 (Ducky's post) |
| All times are GMT -5. The time now is 01:02 AM. |
