2001 SC2 Window switch
My window switch (console) has been sticking and only works part time, can someone tell me how to get it out of the case so I can clean it. Someone spilled a drink into it.
I have the same problem, but only on the driver side window. The switch doesnt stick, but the window gets stuck up when it is cool outside. For some reason it works fine when its warm outside with no problems. Im thinking its an electrical switch issue not the motor. Hopefully ill have the problem fixed within the next few day and i will let you know what the problem might be.
I was able to pop it out with a flat head screw driver with no problem at all
