New to the forum....My son recently rear ended someone and since then, the tail lights don''t seem to work. We replaced the damaged front end (headlight/passenger fender/hood/etc.) but the tail lights are the only thing left. We''ve checked fuses, and all seem to be ok. Any other suggestions?
Check the wiring, mayby when the front end got damage the wires also might of got nicks(doesnt take much), so try grabing the wires and moving then back and forth to see if any changes happen with that occuring if the lights get bright and din while moving the wires i would get that looked at since that could start a short in the wiring harness and you''''ll see a smoke show through the vents, as i did in my dakota.Edited by: radar2k
| All times are GMT -5. The time now is 08:31 AM. |
