-   -   2001 SC1 SOHC Secondary Air Codes (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/2001-sc1-sohc-secondary-air-codes-10460/)
stormie Feb 10, 2016 02:57 PM
So I need some help. I purchased a 2001 SC1 with 184,346 miles on it from a used car dealer (trusted, family does a lot if business with them over the years) five months ago as is to commute to and from campus every day. Just as I was getting ready to get it inspected, the secondary air system code popped up. I tested the relay and pump, both are good, replaced the vacuum line (someone glued in the check valve backwards), replaced the EGR valve and O2 sensors, and cleaned out the built up carbon in the exhaust manifold. Each repair was done after the last failed to clear the codes.
The check engine light finally went off and the code was cleared. To test it, I went on a day trip, 200ish miles round trip. The light stayed off for almost a month. It came back on last week and I don't know what else to do. The guy I bought the car from helped me figure out what to do each time but we are both at a loss now.
What do I do now?!? I still need my car to commute back and forth to classes and I don't have a whole lot of money to dump into it. It cuttently has 193,562 miles on it.
19bonestock88 Feb 10, 2016 09:53 PM
Please post up the codes that the car threw, so we can get an idea what's going on...
stormie Feb 10, 2016 09:57 PM
P0410
02 LW300 Feb 10, 2016 10:27 PM
This is a pretty good diagnostic for your po410
Find a Shop
Get an Estimate
About Your Car
Why Certified?
For Shop Owners
Log In
Sign Up
FOR SHOP OWNERS
Find a Shop
Get an Estimate
About Your Car
Why Certified?
Log In
Sign Up
Encyclopedia›OBD II Codes›P0410 - OBD-II Trouble Code (Saturn)
Auto Systems and Repair: P0410 - OBD-II Trouble Code (Saturn)
OBD II Fault Code
OBD II P0410
Fault Code Definition
The Secondary Air System pumps outside fresh air into the Exhaust System during cold engine start up. This additional air helps burn up the highly rich exhaust emissions that are produced when the engine is warming up. The Secondary Air System typically has an Air Pump and some tubes or plumbing to route the air. The system also has a solenoid and Check Valve(s) to control the air flow.
Symptoms
Check Engine Light will illuminate
In many cases, no abnormal symptoms may be noticed
In some cases, the engine may hesitate on acceleration
Common Problems That Trigger the P0410 Code
Defective Air Pump Check Valve(s)
Faulty Air Pump or Air Pump Relay
Faulty air control solenoids or vacuum lines
System may be restricted or plugged with carbon
Common Misdiagnoses
Air Pump Check Valves function, but are slightly restricted
Air Pump is replaced when the relay is the problem
Parts are replaced when the the system is restricted or plugged with carbon
Notes
Many Saturn vehicles set a code P0410 due to a restricted air passage in the cylinder head
Study the Diagnostic Theory section below to learn about the scan tool data that indicates a restricted air passage
Learn more in the Diagnostic/Theory section at the bottom of this article
P0410 Diagnostic theory for Shops and Technicians
When a code P0410 is set, the PCM is not seeing the front oxygen sensor voltage drop sufficiently when the Air Pump is supposed to be adding outside air in to the exhaust system to burn off the excessive HCs and CO that are created during the cold start of an engine. One should test the system with a data streaming scan tool, during a stone cold start up of the engine. Some scan tools provide the Technician methods to test the Secondary Air System or SAS when the vehicle is already warmed up, but this feature is not present on all scan tools.
Cold start the vehicle and watch the front oxygen sensor(s) on the scan tool data stream. After about 5-10 seconds, you should hear the secondary air pump start, it actually sounds like a vacuum cleaner running under the hood. Just as the Air Pump kicks in, the front oxygen sensor(s) voltage should go to less than .125 volts ( 125 millivolts ). If this does not happen, then you have verified a fault condition in the SAS or Secondary Air System.
If you do not hear the Air Pump Motor start, then check the SAS Air Pump and relay.
If you hear the motor, inspect the components that control the Air delivery such as the Check Valve Solenoid, the Check Valve and the rubber hoses, metal piping and passages.
On Saturn vehicles with the metal air pipe that connects to the cylinder head, if the air pump is running but the oxygen sensor voltage does not change, remove the metal air pipe that goes in to the cylinder head and inspect the air passage to see if the passage is plugged or restricted.
Related Items
Secondary Air Injection Error
need new Air injection pump.
P0410 & P0491 Codes
secondary air injection check valves
Haynes shows no Secondary Air Injection System on my vehicle for P0410 Code
About Your Car
Questions
Problems
Recalls
Reviews
Car Care Advice
Get an Estimate
Tell us a symptom, service or repair for your car
Show Repair List »
For Shop Owners
Our master mechanics certify top auto shops through rigorous testing to ensure an exceptional level of quality
About RepairPal
Team
FAQ
Partners
News & Media
Blog
Support
Advertise
Contact Us
Car Care Advice
Auto Basics
Common Problems
Hints & Tips
How To Guides
Q&A
References
Troubleshooting
MyCar
Checklist
Encyclopedia
Brakes
Drivetrain
Electrical & Lights
Engine
Exhaust & Emissions
Heating & AC
Scheduled Maintenance
Suspension & Steering
Repair Shops:
San Francisco
New York
San Diego
Chicago
Los Angeles
Denver
Dallas
Houston
Seattle
Las Vegas
San Jose
Miami
Sacramento
Makes:
Ford
Toyota
Honda
Chevrolet
Dodge
BMW
Acura
Nissan
Volkswagen
Chrysler
Lexus
Mercury
Cadillac
Hyundai
Buick
Volvo
Audi
Models:
Honda Accord
Toyota Camry
Honda Civic
Acura TL
Toyota Corolla
Ford Taurus
Volkswagen Jetta
BMW 325i
Ford Explorer
Ford Escort
By using this site, you agree to these terms: TermsPrivacyCopyright © 2016 RepairPal, Inc. RepairPal® RepairPal Certified®
derf Feb 12, 2016 01:15 AM
NICE Andy. Thank you
