My sunroof has been leaking for a while. I took the headliner out to blow out the drain tubes. I then tested it by spraying the closed sunroof with a hose. It turns out the leak is around the copper tubing that comes from the sunroof motor. Has anyone else had this problem? What is inside the copper tubing, and how can it be resealed? This is not a problem with the drain tubes. Thanks in advance for responces. |
| All times are GMT -5. The time now is 06:51 AM. |
