1995 Saturn SC1 Brake Bleed Problem
Old Dec 15, 2023 | 08:32 PM
troyld's Avatar
Default 1995 Saturn SC1 Brake Bleed Problem
Hello All,
I'm new to this forum and this is my first post. I'm looking forward to being an active participant and appreciate any help
with the issue below.
I'm looking for help with brakes that go to the floor.
Here's what i've done so far using a pressurized Motive Bleeding kit and still my rear passenger brakes won't bleed:
1. installed and bench bled a new master cylinder
2. successfully bled 3 (driver rear, passenger and driver front) of 4 brakes
After doing the above the brake pedal still goes to the floor.
When I tried to bleed the passenger rear initially a small drop of brownish colored fluid appeared in the tube.
After the initial fluid appeared no more fluid appeared. I even removed the bleed screw, checked the bleed hole
to see if was clogged and didn't noticed any blockage.
Even with the bleed screw removed there is still not a drop of fluid showing. I did check the brake lines and noticed
a small leak on the front passenger side. Even with this small leak the other brakes bled fine so didn't think it was part
of the issue.
Having said all of that, I'm looking for some input on what to try next?
Thanks in advance - Troy
Old Dec 16, 2023 | 08:08 AM
You should remove that rear brake line and see if you can blow it out with compressed air. That's what I'd do, but I'm not a mechanic and have never worked as one.
Old Dec 16, 2023 | 09:09 AM
Does the right rear brake line run separately to the front of the car? Did you just purchase this car with this brake problem or is this a sudden onset problem? Answers will help diagnose the problem.
Thanks
Andy
Old Dec 16, 2023 | 11:30 AM
troyld's Avatar
Thanks
Andy
yes
this is sudden onset problem
Old Dec 17, 2023 | 10:05 AM
I suspect that the leak near the right front of the car is the source of your problem. The steel line may be rusted through and collapsed there. All the brake and fuel lines on my car run down the passenger side above some aluminum shielding.
C.LUCENTA
Saturn Aura
Apr 20, 2016 01:48 PM
SilverCoupe#SC2
Jan 12, 2013 08:38 AM
ngrome
Mar 21, 2011 09:16 PM
ngrome
Mar 16, 2011 04:16 AM
AlexT
Feb 9, 2007 10:46 PM
