-   -   02 sc2 instrument panel lighting (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/02-sc2-instrument-panel-lighting-7576/)
john doe Feb 25, 2013 06:03 AM
ok ,i went in to see why my overhead lighting in the instrument panel wasnt working .2 bulbs are blown .now today the wife says half the panel lights went out (great) i break more stuff than fix it anymore .
anyway .looking at dashes online it appears the bulbs are all the same (the ones i can see) so i need a few of these
http://imageshack.us/a/img577/2637/dscf1019s.jpg
http://imageshack.us/a/img827/9126/dscf1020rt.jpg
if you can help with working ones let me know .or if you know a source please post a link .
i have not had my cluster out yet but heres what they look like on ebay
http://img.auctiva.com/imgdata/1/6/5...05472878_o.jpg
i also read online that there may be lights inside that you need to solder in to replace ,this true??
or are these all the lamps?
thanks .....please help,mad wife.....:(
OceanArcher Feb 25, 2013 08:20 AM
Any of your local after-market parts houses will carry those bulbs -- some may even have an LED version (probably pricey). I don't think the LED types will work very well with the dimmer circuit in your car. Frankly, I haven't tried ...
john doe Feb 25, 2013 09:48 AM
problem is the bulbs in these are very hard to remove and you need to solder new ones in ,the guy at pep boys broke one of the little metal tabs that make contact so now i need the holder as well .
john doe Feb 25, 2013 10:36 AM
napa had a bulb and socket very similar for 1.69 each so i grabbed 2 .will try them tonight .
http://imageshack.us/a/img109/4879/dscf1021e.jpg
OceanArcher Feb 25, 2013 05:19 PM
Ooooohhhh -- I understand your concern. Actually, my local ZutoZone has the bulbs complete with the plastic clip already attached ...
john doe Feb 25, 2013 06:25 PM
happy to report that these worked fine .i now have overhead lighting ,at least we can see the gauges now .
just going in and touching these bulbs burned out half the other bulbs that were working .maybe it was the hit on the dash pad to reseat it that broke the bulb filaments .thats what i am thinking .
i hope this isnt the one that you gotta totally open up and solder replacements into .wont know until i get time to totally tear into it .
derf Feb 25, 2013 09:26 PM
yeah shock will wreck those buggers.
You might consider replacing all of them while you're in there, 'cause you don't want to be in there again
Octavious Feb 25, 2013 09:51 PM
I replaced all my backlighting with LEDs - some of the bulbs have the plastic attached to them.
It looks like that board only has the top lighting that is replacable (if it lights from the back, you may have to open it and see)
john doe Feb 26, 2013 06:05 AM
found this online .it would appear replacing all the number 1`s should get me my back lighting back .
http://ww2.justanswer.com/uploads/xs..._213639_1a.gif
sw2cam Feb 26, 2013 06:25 AM
Post the part number and where you bought them
