-   -   01 SC2 miss fire #1 (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/01-sc2-miss-fire-1-a-3546/)
KEV64 Jul 25, 2009 10:43 AM
01 SC2 miss fire #1
MY SC2 HAS A MISS FIRE IN 1. I HAVE CHANGED PLUGS WIRES AND 1 COIL PACK. WHEN I RESET COM. CHECK ENG LIGHT GOES AWAY BUT COMES BACK IN ONE DAY? can any one help!??
RjION Jul 25, 2009 10:51 AM
Pull the plug wires off one at a time from the plugs. Start with the plug on the passenger side. You see oil, change the cam cover gasket and plugs.
KEV64 Jul 28, 2009 08:20 PM
Thanks for the info! I will try that soon. Can you tell me whats happening to plug?
RjION Jul 28, 2009 10:25 PM
Whats happening to plug? what may I ask are you talking about.
If the cam cover is leaking oil into the plug well then the spark is going to ground not to the plug. It would do the same if the spark plug well had water in it.
KEV64 Aug 4, 2009 11:40 AM
Thanks for the help ! Will do the work today new ngk plugs and gasket set. Will let you know what happens next!
