For pwr passenger mirror for Black/Gold 1997 SC2
Need passenger side mirror+ housing and the corner trim piece it mounts to. Will settle for just mirror plate itself as I love to epoxy.... Pls quote w/shipping to NJ Thanks Derf |
will one from a 94 sl fit? let me know asap
Don''t think it will, as that is a 1st gen sedan and the 97 is a 2nd gen coupe....
Thanks, though... |
I do believe that 97-99 will fit
Thanks Mike.
Actually do you know if the trim portion is available as a separate part? I ask because 1)I have replacement glass in hand. 2) I can order the motor alone (the mounting tabs all snapped on mine so I have no way to re-mount mine to the mirror housing even though the motor works 3) The mounting fasteners from the trim piece all tore out of the trim piece, leaving me no way to remount the repaired mirror housing assembly to the car. If I can order the trim portion separately, I can then fashion a mounting plate for holding the rest of the mirror assembly to the trim piece (and thus the car) At worst I can epoxy it, but it I ever hit it again, I fear that the damage would be worse since the mirror will no longer be able to tear away as it did... |
Actually will settle for black trim piece that mounts to door and a functioning mirror motor (97 -2002)
Otherwise it''s off to junkyard row in Philly(ah, the memories of my youth) |
Hey man do you still need the mirror? ... If you do post up and I''ll go and dig in the garage as I think I have one but I doubt it''s the right color.
Indeed I do.
My mirror housing itself is fine I need the black trim piece that mounts it to the door and a functioning motor. I will disassemble what you send me to get the needed pieces to rebuild mine (so I don''t need to paint it. IM me through the forum and we''ll sort out logistics. Thanks Derf |
| All times are GMT -5. The time now is 07:11 AM. |
