Looking for 2057-compatible tail/brake light bulb socket for 97 SC2
2 Attachment(s)
I cannot believe the difficulty I am havin with locating a 2057 brake / tail light socket for my 97 SC2.
Most GM 2057 sockets have 3 small tabs spaced 120 degrees apart. The taillight housings ( and therefore the bulb sockets ) have a 4 tab design, with a large one at the top, 2 smaller ones at 3 and 9 oclock, and an even smaller tab at 6 o clock. I have been to NAPA, Autozone, Advanced, no dice. All the universal ones have 3 tabs as described above. The bulb socket was never sold as a standalone item -- only the wiring harness has a part number, so I have no way to crossreference a part number for just the bulb socket. If ANYONE has a Saturn parts car around, could you please check the socket and taillight housing and see if they match the attached pictures? And if so, would be grateful to obtain a few from you. I doubt they were limited to just the S series, but that is most likely to be a match across most years--97-2000 for sure before they changed the wiring harnesses. THANKS! Derf Thanks PS -- you cannot see the bottom tab on the socket in the pic but it is there |
