Vue motor mounts for manual transmission
I had a new catalytic converter installed and they told me it needs new motor mounts asap. I have a 2002 Vue, manual transmission. Mechanic says he can't find them anywhere. I am hoping someone can direct me to a source. I'm told there are 4 that need to be replaced. Any help is appreciated. Thank you.
RockAuto carries the forward transmission mount, the rear transmission mount, and the engine mount for cars with manual transmissions. I did not find a listing for the top (left) transmission mount. eBay has a couple of sellers that are selling packages of all four mounts (~$200) for manual transmissions IF you have a 3.0L V6. They have no similar listings for the 2.2L 4 cylinder with manual transmission. The three manual transmission mounts (front, rear, top) are the same part number regardless of the engine. Not the same part, obviously, but the same part number for either engine.
Originally Posted by oldmarine
(Post 79863)
RockAuto carries the forward transmission mount, the rear transmission mount, and the engine transmission mount for cars with manual transmissions. I did not find a listing for the top (left) transmission mount. eBay has a couple of sellers that are selling packages of all four mounts (~$200) for manual transmissions IF you have a 3.0L V6. They have no similar listings for the 2.2L 4 cylinder with manual transmission. The three manual transmission mounts (front, rear, top) are the same part number regardless of the engine.
| All times are GMT -5. The time now is 05:01 AM. |
