Vue motor mounts for manual transmission
Old Sep 29, 2025 | 01:08 PM
Desert Dreamer's Avatar
Default Vue motor mounts for manual transmission
I had a new catalytic converter installed and they told me it needs new motor mounts asap. I have a 2002 Vue, manual transmission. Mechanic says he can't find them anywhere. I am hoping someone can direct me to a source. I'm told there are 4 that need to be replaced. Any help is appreciated. Thank you.
Old Sep 29, 2025 | 03:27 PM
oldmarine's Avatar
RockAuto carries the forward transmission mount, the rear transmission mount, and the engine mount for cars with manual transmissions. I did not find a listing for the top (left) transmission mount. eBay has a couple of sellers that are selling packages of all four mounts (~$200) for manual transmissions IF you have a 3.0L V6. They have no similar listings for the 2.2L 4 cylinder with manual transmission. The three manual transmission mounts (front, rear, top) are the same part number regardless of the engine. Not the same part, obviously, but the same part number for either engine.
Old Sep 29, 2025 | 03:38 PM
Originally Posted by oldmarine
RockAuto carries the forward transmission mount, the rear transmission mount, and the engine transmission mount for cars with manual transmissions. I did not find a listing for the top (left) transmission mount. eBay has a couple of sellers that are selling packages of all four mounts (~$200) for manual transmissions IF you have a 3.0L V6. They have no similar listings for the 2.2L 4 cylinder with manual transmission. The three manual transmission mounts (front, rear, top) are the same part number regardless of the engine.
I should have specified I have a 2.2L, manual. Thank you for the info. I will check it out.
suprasonic
Oct 6, 2025 09:10 AM
sylvanmike52
Sep 28, 2024 05:56 PM
Farmer22
Oct 7, 2023 08:04 AM
Reicher
Oct 26, 2020 06:31 AM
deirdre
Jun 10, 2019 07:08 AM
