New and need help 2000 LS300
I bought a 2000 ls300 with a 3.0. It had a blown engine. I bought a used motor and installed new plugs, valve cover gaskets, water pump, all timing components, and put the engine in the car. Engine runs, but throws a p0301 cylinder #1 misfire. It also backfires in the intake. I've checked the timing multiple times and its spot on. Not for sure where what else to check. If it was just the p301 I would check plug, coil, and injector. But with it backfiring, I'm at a loss.
No compression on cylinder #1. This is the 5th engine I've gotten that has had compression issues. 2 from on place, 2 from another, and this one from a different one. Going to call tomorrow and see if they will help pay to have the heads reworked. Its under a 90 day warranty. ugh and double ugh.
Alteran2003
Dec 18, 2012 04:10 PM
nlange
Sep 21, 2009 08:27 PM
