Need help
I would start with a good test light and test both sides of all the fuses. There are several that power the BCM in the under the hood fuse panel there are also fuse panels in both kick panels inside. If all the fuses check ok then I would pull and reinstall all fuses to sweep the connections in the fuse panels. I suspect that you have a bad BCM but check a few things first.
