where are the number on the auto trans to tell the year of the trans and what number thell the year ??i bought this 1994 saturn sl2 and it had a auto trans that shifted once good then go in limp code so i pull it out and put in other one same thing pull it out and same thing then found out it has to be a 1994 trans NEED ALL THE HELP I CAN GET THANKS
HOTROD1935-I would suggest calling around to local Transmission shops to see if they can help you with your problem.You could also try Saturn dealership.Good Luck...
