I have a 2000 LS1.
I have just started to experience problems with the wipers, They will not return to the 'home' position. They stop where ever they feel like it. If you run them in Low or High speed they will continue to operate ok, but when you turn off power they have a mind of their own. Intermittent operation same issue mind of their own, they do not make a complete cycle. [img]smileys/smiley5.gif[/img] Any ideas? Dazed and Confussed [img]smileys/smiley5.gif[/img] [img]smileys/smiley29.gif[/img] Edited by: TCPAUL |
I've read about similar problems on other websites and everyone agrees it's an electrical thing. There's some sort of relay switch--I think in your steering column--that can be replaced that will fix that problem. If you look your problem up on Google, you'll find the exact answer.
