Just put in new motor a month ago and was running great till I run a yellow light speed up to go then it just cut off I checked the fuel it is geting gas It is getting fire. but will not start it will start if I spray starting fued in it then cuts off run a hot wire to the fule pump and checked the inlet line gas is coming in and the return line gas coming out but no start unlessI spray starting flued in then it starts right up but only runs till it burns outI do not think the Injectors are working is it the PCM or what.??? HELP!!!!https://www.saturnforum.com/smileys/smiley19.gif
check fuses for injectors
i would say fuel pump, i had same problem sprayd stuff in the carb of my dakota and it started as long as i sprayed...fixed fuel pump, fixed problem ...
get someone to turn the key(just for power/music)dont start the car. As you listen to your gas tank, listen for a humm..if no noise then thiers the problem. Take the gas cap off before doing the test to hear better.
