hey everyone, I own a 1995 saturn sc2, and recently I decided to remove the stock intake and install a short ram intake. When i removed the stock intake and everything, i noticed that attached to the stock air filter box was this cable with a connector, im assuming this is a sensor of some type. Obviously it was removed so the rest of the stock intake could be removed, however once i went and installed the new short ram intake, i realized that their was no place for me to plug this cable into with the new intake. If anybody can help me on where i can install it to, what its called, and maybe how i can install it with a short ram intake in it, i would appreciate it so much, thanks for your help!Edited by: sw2cam
Im aware its not a race car. Its what i can afford though, help would be appreciated.Edited by: sw2cam |
from whut ive searched, leaving the stock air box is the way to go. the sensor is the mass air flow sensor. you need this of course.
check this link http://www.redlineforums.com/forums/...ion/6539-short -ram-install.html |
clearly you need this, i would think however i should be using it installed the correct way. How can i mount this sensor to my new intake? Edited by: sw2cam |
It's a 1995 SL2 with a 1.9L engine, it didn't come with a mass air flow sensor. Edited by: sw2cam
Its the IAT, Inlet Air Temperatur sensor. Drill a hole towards the end of the intake pipe near the filter. Install a rubber grommer and press the sensor into place. Any quality aftermarket intake would of come with the provision. Edited by: sw2cam |
ahhh...my bad on the maf sensor... inlet air temp would be correct. and yeah it should plug into the new pipe. unless of course the intake is an autozone piece o crap..it isnt is it?
