water leak
have a 2000 sc2 water leak is on back of motor on black plastic piece under air intake does anyone what that peice might be
called? and how to replace it? |
Sounds like it may be that part of the intake manifold that likes to crack. Is there a rubber hose attached to it? They do make a part to replace just the damaged section of the manifold. You can find it on Ebay and possibly on one of the Saturn websites.
o ok thanks it is leaking at the last bolt closes to to driver side. do i need to get a whole new manilod? are they hard to replace?
Like I said in my previous post, it only replaces the defective section. You have to modify the existing manifold. It is easy to do.
| All times are GMT -5. The time now is 08:16 AM. |
