< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> I'm installing underbody neon lights on my 96 sl2. everything is working except when i screw in the negative post to my battery in all the way my lights get no power, and then i noticed that if i un screw it a little bit then my lights work but i can't start my car. i cant figure out whats wrong, please help me. |
it sounds like you are creating a short in the system somewhere..i would check over all of your new wiring to make sure everything is insulated properly.
ok thanks for the suggestion. I'll post some pics of it if i get it working if anyone is interested so check back. < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
what color is your car, and what color are the tubes? let me know how it works out for you!
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> my car is green and my lights are green. i'm kinda busy this weekend, so i probably wont get to it til next so check back then for some pics. |
im here everyday...i look forward to the pics!! [img]smileys/smiley1.gif[/img]
